Read Only Memories: Neurodiver teszt
gp A 2064 folytatása négy teljes évet csúszott a legelső tervekhez képest – a jövő transzhumanista világa még mindig roppant érdekes, a történet azonban már nem robotok, hanem agybúvárok körül forog.
AMD Ryzen 9 / 7 / 5 / 3 5***(X) "Zen 3" (AM4) topik összefoglaló
fudi2002
fudi2002
fudi2002
Érdekességképp:
Here is a list of the reasons for all the errors in TM5 (in order):
Error 0 refresh stable error = voltage cutoff choke
Error 1 = Simple Test 16mb ~ can be voltage related, can be tRFC issues,
tiny timeout issues for example tRRD_L looks like a bit awkward
Error 2, 12 is a timeout issue, somewhere something ends too quickly or you lack voltage and cells are not recharged in time
a sync issue with other words which's first culprit is voltage somewhere or resistance somewhere
Error 3 & 4 by checking the MT.cfg - are MirrorMove errors
That set shows tRFC 2 issues and this tRFC "auto predicted"? is wrong.
tRFC is so far always even
as tRFC stepping are 32,16,8,4,2,
Error 5 then 6 is a timings missmatch between dimms (data mirror move)
Error 6 is purely related to the IMC, be if procODT, CLDO_VDDP or vSOC
~ it translates to "i couldn't even start transfering data, i crashed"
4- 6x error 6 result in full bluescreen
Error 7, 11 are burst tests
it will error out if if CAD_BUS is not optimalwill error out if tRFC is too lowmostly errors out only after time
Error 9 burst test 4mb is a voltage stability issue
If you've lowered tRP, increase vDimm a tiny bit
If you've increased tRP to longer delay, decrease vDIMM +0.01, one tiny step
Error 10 mostly affects the first 5 main timings
- noticed it can be tRCDWR to RD. can be tRP too, but it also can be the last two tRDWR & tRDRD which don't play well with your main tRCDWR / RD
Error 13 = Simple Test 64mb, timeout while transferring big data
= full crash, nearly always related to voltage ~ as memory was not able to autocorrect it
Error 14 we know is MirrorMove Omb, a timeout issue
- it can error after the 2nd or 3rd pass if something is off my some ns and just "got lost"Szakmai kérdésre privátban nem reagálok.
fudi2002
fudi2002
Aionál arra gondlhat hogy csövekkel felfelé van a borda rögzítve, de nem aio userként ez nem tudom mennyi difi.
Ramnál mi a gond? Sztem kb mindenhol (fórumon itt 5000+ hsz minimum) le van írva, közte a könyvben is, hogy 2,4 ha két modul...
fudi2002
válasz ScomComputer #13306 üzenetére
Valahol érteném régebben, intelesek voltak, csukóból szerelnek, nem olvasnak. DE, azért 1-2 éve már a ryzen dominál az eladások terén, tehát ma ez már nem nézhető el...
fudi2002
Mikor nem kap terhelést (bench) akkor hozza amit beállítottál. Mikoris valóban használatba kerül a memória és hibázik akkor pedig visszavesz pár értékből. Amennyiben az adott értékekkel valóban stabil gdm off, abban az esetben a gdm on nem jár hátránnyal.
fudi2002
válasz kicsipapucs #13325 üzenetére
Azért titkon be kell valljam, az első lap ami megdobogtatta szívemet...
fudi2002
A csodatesztek alatt ugyanazt hozza, mivel azok nem töltik fel a memóriát. Leírtam már. Ha gdm off stabil akkor hagyd úgy. Milyen tm5öt futtatsz? Ugye vágod hogy a gyári beállítás tm5nél lószart sem ér? 1usmus conf pl 30-60p ami már jó.
fudi2002
válasz #68216320 #13458 üzenetére
De akkor minek is terhelne több szálat, mikor a gput 48%on simán kiatartja hogy meglegyen a 60fps? Gondolkozzunk mán. Jobb lenne ha szétosztanná szálak között kisebb freki mellett illetve a magkommunikáció okozta lassulást megkockáztatva?
fudi2002
válasz GIORGIONE76 #13674 üzenetére
Valóban felfűt a vsoc, én sem támogatom a túl magasat. De dual rank if1900-on szinte kizárt hogy 1.0v-on stabil legyen neki. Ráadásul alacsony vddg-vel.
fudi2002
válasz MPowerPH #13681 üzenetére
Tipikus soc fesz gond. Belefutottam anno abba, hogy a c16-os beállításaimról úgy tudtam c15-re átállni, hogy meg kellett tunkolnom a vsocot, de még a vddg-t is. Ha imc hibás a proci, az hibázik kb mindenhogyan. C15-16-14 tökmindegy. Alacsonyabb if-en megy, aztán már ott sem, de ez ritka eset, zen3-nál nem is olvastam még ilyenről, zen2-nél is fehér holló kategória (oc mágusok akik megtunkolták a vsocot, vélhetően úgy sikerült ott is)
fudi2002
válasz MPowerPH #13686 üzenetére
Emléxem arra a 3600asodra, finoman szólva furcsa dolgokat művelt az a cucc. Sztem azzal vmi nem volt okés, de durván.
1.05v nagyon jónak számít 2ccdsnél. Albigator 1.03v pl érthető 1ccd miatt. De az if1900(5900x - 2ccd) 1,0v soc nem jön össze, vagy valami mutogatnivaló darabot kapott az amdtől..
